a $50, low pressure 400btu regulator the heater works better than I ever imagined. I use it every week.
I have a different brand but use it to shower, wash dishes, daily.
I have it on a rotary timer switch in an RV; the water pump and a 12V>3V transformer are fed by the timer output. I didn’t want to deal with expensive D batteries and it works great. I do have the battery holder and a pair of D’s as a backup but I’ve never needed them. 12V solar supplies the power.
I agree these type units are fantastic. I use a smaller unit and gas use is very very low but I could get 140*F water if I wanted. (I don’t want 140* water….)
Please elaborate on the 400btu regulator. Is this a gas regulator or a water temperature balance regulator?
The unit I bought came with a propane regulator and hose to connect to a 20# cylinder but I made up a copper 3/8 line from the former RV water heater supply and just used the RV regulator.
One recurring problem I have had with these is the water flow switch internal to the unit. It is supposed to activate the ignition and gas valve when water flow occurs (they all have) and when water flow stops gas valve should be closed. 3 units have failed- after six months or so of use you would turn of the shower but the burner would continue to run. Eventually the over-temp/high-limit would cut out but sometimes it would boil water and blow out the plastic RV hot water line.
I think all of these units are a safety concern. It appears that there’s a bunch of different brands with identical appearance, parts, and architecture. I’m not saying don’t use them, I’m saying they need active safety mitigation by the user.
I currently ’solve’ this consistent safety problem with a switch so that when I turn off the shower I can instantly unpower the unit which closes the gas valve. I do that habitually although I have noticed the unit will shut down 50% of the time.
My recommendation is to:
- Provide a convenient power cutoff switch
- Provide a gas shutoff valve at the unit
- always run a “whole house” water filter in-line ahead of the water heater.
Basically my conclusion is that the tiny waterflow sensor is easily gumped up and is most likely to be the cause of failure. It’s not a convenience failure- the gas valve not closing at no-flow is a safety failure! I have had 3 or 4 failures in the past three years, all the same issue. That is a concern!
