laraku
- Dec 26, 2021
- 16
Hi all,
I've been following the forums for awhile now and finally made an account to participate in hopes of creating an up to date Lithium titanate (LTO a.k.a. Li4Ti5O12) battery build thread. There haven't been a lot of threads on this recently it seems (I've read most of them now). I really appreciate the time many people take to help others and hope to contribute here too.
The situation:
I'm looking to replace my current dying AGM batteries and after many hours of research I'm planning to get some LTO Toshiba cells that I've sourced and build some batteries with a friend who has more electrical know how. (They are not in the scib packs). I'm pretty set on LTOs as I want super safe, long-lasting batteries that can withstand low Ontario temps without heat when I'm away for days or weeks.
My setup:
1. If I'm looking for around around 12 kwh (500ah at 24v) what cell configuration do you think I should go with? I was thinking 12s6p as I'm thinking of someday changing to 48v when my current inverter dies and this would give me four batteries of 72 cells with around 288 cells total (I'll also get a few extra).
2. What BMS at what amp rating would you recommend these days given answers to #1? Quality and longevity are important. I understand Chargery, Daly, and Batrium are options from other threads. Any advice on best places to purchase too? @wild01 also wrote recently that a BMS isn't even needed, only a balancer. Thoughts? I'm thinking a 200A or 250A daly 15s LTO BMS. Not sure yet if 250A exists.
3. Does anyone have experience in Ontario acquiring bus bars and other needed items? Not sure how common they are for these size of cells or if I should just make my own. Any advice on sourcing needed materials? Advice on copper vs aluminium?
4. Are there any other issues or advice you can think of to mention or resources you are aware of (e.g. will my charge controller work to charge these?)? @Bob B @Will Prowse @120vjohn @Freibeuter @Claudi @erik.calco @thedodgersonline @toms @wild01 @Brendon @Craig
Thank you so much for your advice and insights in advance! I will document my process and share.
Kind regards,
Trent
Resources
For anyone interested working on LTO builds here are some links to threads and videos that I've found:
A bit outdated now but some useful info.
https://diysolarforum.com/threads/lto-cells-on-batteryhookup-com.2541/
Some useful background info
https://www.insightcentral.net/threads/used-lto-scib-questions-comments.126355/page-2
Very interesting points
https://diysolarforum.com/threads/lto-bms-sources.27641/
Functioning build
https://diysolarforum.com/threads/yinlong-lto-bank-for-my-off-grid-cabin.6733/
Consideration?
https://diysolarforum.com/threads/lto-bms.5696/#post-58711
Good info
https://diysolarforum.com/threads/lto-scib-battery-bank-for-off-grid.7969/
diysolarforum.com
A bit of background. Old though and some mentioned issues are not considerations for me or have been worked out
An LTO bank build (different cells than me)
Another build
Another build
This guy has some videos of his LTO set up with some good points (its 48v with the yinlong cells)
https://youtube.com/c/MikeLawrence
Likely not needed?
http://www.ejbattery.com/productview_35.htm
The situation:
My setup:
- I've been running a 240 watt x 3 24v solar setup since 2016 with AGM batteries (4 12v 240ah batteries configured to 24v).
- I've just added another 240 watt x 3 string and I'll be adding 3500 watts more of solar panels this year (haven't decided which ones yet in what configuration).
- I have a 24v Magnum 4024 pae inverter (input battery voltage range 18vdc-34vdc, so should be good) and an Outback Flexmax 60 charge controller so far (will be getting another charge controller for the new array or if I need something different for the LTOs).
- The cells I'm getting are the 2.3v 20ah Toshiba prismatic cells (new condition hopefully? and not in scib packs).
Kind regards,
Trent
Resources
Functioning build
Consideration?
Good info
Question regarding capacity testing of LTO cells
Dear all, thanks to Will Prose's great videos regarding LTO cells, I decided to run my photovoltaik plant on 40Ah LTO cells ! So far so good - I have ordered 10 Sets of 24 = 240 cells and now I want to test them before installing them, so that I do not get a buggy cell in my setup. So I have...
Another build
Another build
Likely not needed?
