The times in life I got my ass spanked publicly for being ditzy about stuff that was actually important or dangerous are the most the most remembered
Yea me too , in fact just the other day I was ...
Yes, there are multiple things happening here at the same time. It happens.As far as I know, not.
But –of course– everything burnable around can be put to fire by the high temperature.
Oxygen is needed. Try starting a fire in space. Even nuke blasts are muted due to no atmosphere.Then you don't know. Oxygen is being burned. The breakdown reaction is producing its own oxygen, but as you saw in the demo video, removing access to atmospheric oxygen significantly reduces the intensity of the fire.
Only if oxygen is present
No wonder, burnable stuff around the battery burns...Then you don't know. Oxygen is being burned. The breakdown reaction is producing its own oxygen, but as you saw in the demo video, removing access to atmospheric oxygen significantly reduces the intensity of the fire.
...which reduces the intensity of the secondary fire.Only if oxygen is present
If you read thru the followup, it seems it was some type of DIY BMS and he was charging over 3.65V per cell.
This guy's LiFePo4 burnt , a good few years ago.. he thinks it was a BMS issue. Apparently it burnt so hot it melted the gearbox ?
Yes but just goes to show LiFePo4 can and does burn under the right (wrong?) conditionsIf you read thru the followup, it seems it was some type of DIY BMS and he was charging over 3.65V per cell.
No flame until second puncture when outside oxygen could enter.Was High-tech labs video of one being punctured not self-fueling?
The sun does pretty wellOxygen is needed. Try starting a fire in space.
An interesting test would be to puncture a LiFePo4 cell in a vacuum to see what happens. Hey, lets get those astronauts on the space station do a test! That would be a cool space walk, carry a battery cell outside and stick an icepick in it.The sun does pretty well
... but that's nuclear, not burning.
AFAIAA burning requires an oxidant, but that doesn't have to be oxygen.
LiFePO4
YesAre you saying the 'O' in LiFePO4 stands for oxygen.... ?
Is that Will's next YouTube video?An interesting test would be to puncture a LiFePo4 cell in a vacuum to see what happens. Hey, lets get those astronauts on the space station do a test! That would be a cool space walk, carry a battery cell outside and stick an icepick in it.
My brain hurts... if Lithium is lighter than air, why don't we mine it from the atmosphere? (genuine question!!)LiFePO4
Lithium Atomic mass: 6.9410 u
Iron (Fe) Atomic mass: 55.845 u
Phosphorous Atomic mass: 30.974 u
Oxygen Atomic mass:15.999 u (x4)
However, the gasses it release are flammable. If ignited by a spark (like Dexter's second punch with a metal bar), could then ignite wood structure. Unless finished basement with everything is sheetrocked and that provides sufficient protection.
sorry, been away, it's 48v LiFe, re-purposed from old Enginer packs for the Prius. They are in metal containers, but certainly not UL by a long stretch.What do you have?
they are only being used as outage backup, so very minimum cycling and narrow 30-75% depth-of-charge range
Most elements are not in their natural state but bound up with other elements in compounds. Hence why most things are in the ground. Ore rich in Lithium is mined and then the Lithium extracted through chemical processes.My brain hurts... if Lithium is lighter than air, why don't we mine it from the atmosphere? (genuine question!!)
And more to the point why do these batteries hurt you so much when you drop them on your foot LOLMy brain hurts... if Lithium is lighter than air, why don't we mine it from the atmosphere? (genuine question!!)
