ramseyjack
been around a day or two
Grace,
Install went fine, but the inverter is asking for a numerical password to make any changes (like switching away from lithium). Also this probably would not be an issue if my account was an installer account. I have different battery setup (32 Tesla Model S batteries run by a unique BMS (Simp BMS for safety) no need to talk to the BMS but need to change the absorb and float voltages to 46V. Thanks!
I am certain it may need a firmware upgrade, this is the older 12K version with the smaller lower connection enclosure.
I need to AC couple an 8KW SMA inverter
