Zwy
Emperor Of Solar
Th 24V case like the 48V has 9 screws for the BMS-Pressure plate. It is pretty even pressure when done right. no need for more screws or attachment points.
Obviously you must not have a decent background in fabrication, even though you claim you do.
When you have all 9 screws installed that plate won't go anywhere. The Mounting Points are as generic as can be. Mine were fine for use with the JK INverter edition and those same points apply to Pace/Seplos & TDT BMS' of the same class. If using a different BMS then that has t be sorted. I can''t imagine you finding a casing that will accept "all formats" of BMS.
I used JK and she made the box according to that model of JK which is also one she offers in prebuilt.
So either the box builder f'ed up like the breaker hole or it is more of a "universal" fit.
The cases are designed to take a variety of cells (see sizes) so compensating for the space difference is up to use... I used urethane foam mesh on the side & at the front to compensate without issues.
Calling it a compression plate is a misnomer because the way it arrived there isn't any compression.
I'm letting members be aware this isn't just a simple bolt together process. Unless they are willing to accept those tradeoffs. I'm not willing so will invest time and talent to correct what I see as deficiencies.BTW: They are working on getting a few other Case Models/Types up for sale soon. They are looking at different formats and how they are setup / assembled (cell orientations & other issues). EVEN GSL has started abandoning packs with cells on their sides after all the problems & issues.
Anyways, I provided more info to help folks make their choices. The rest is up to whoever to make their choices.
