You can order them with your choice of BMS, these are 8s fronts and are the same as the 16s.Could someone send pictures of the Luyuan 16S box? Does it have a fuse/breaker? Or heating? JK BMS? Thanks!
Yeah, I am now using up what's left in inventory and disposing of all the remnants when completed as I'm walking away from all of it. Property & everything being sold late spring and trimming down to One "Adventure Pack" (deluxe backpack with all that I need) and off to tick the last few Bucket List items.That is the reason I went from four box kits to twelve along with extra BMS, screens and breakers. I don’t have everything assembled it will take me some time this year.
Sounds like an adventure, I wish you luck I would like to do the same but stuck in the rut for a while longer.Yeah, I am now using up what's left in inventory and disposing of all the remnants when completed as I'm walking away from all of it. Property & everything being sold late spring and trimming down to One "Adventure Pack" (deluxe backpack with all that I need) and off to tick the last few Bucket List items.
He can impose tariffs on imports to Canada?Unfortunately, The Tariff OGRE is having increasing Tantrums against China and BRICS overall, ramping his threats etc...
Hope for the Best but really expect the worst so you don't get disappointed or let down. These are supposedly going start to be dropped beginning tomorrow, Saturday February 01.
Gotta wonder what Trix will be dropped on everyone on "April 1st".
Canada is doing it's own Tariffs & Duties and No the Orange Ogre can't make us do anything, regardless of what he thinks.He can impose tariffs on imports to Canada?
Did I miss our invasion and you guys became the 51st state?
I do have to say I’ve been seeing tons of “Ontario is Americas best friend/trade partner/neighbor.” commercials over the past few months, very nice.
Made the leap. Time will tell how tariffs work when they arrive on the west coast. Got another case, BMS, screen and batteries to fit.Currently chatting with Amy
I'd buy the 16S Luyuan box and make it a parallel 8S 560Ah box with a pair of BMS's. Of course if you don't intend to carry it.My gut wants to add another 8s 280k battery bringing my total storage capacity to around 20khwr.
But my logical brain says it’d be over kill for the camp until I have my 12k mini split up and running.
I have insulation all around the cells in the truck camper except for the top. I recently finally used the heating pad and was surprised how fast 200W heated the batteries up from about 28°F to around 50°F. The battery is contained inside a cabinet that had the door closed which helps for heating.Has anyone added active cooling to their box? Mine hasn't had to endure hot weather (it's installed inside my camper) yet.
I was thinking about this last night. The box I have (16 cell box) doesn't lend itself to air flow. The only way I can think of to add air flow is on the lid. Cut four holes in the lid. Two holes at the back, two holes near the front. Install fans with the fans at the back forcing air in and the fans at the front pulling air out.
If temps are high on a trip, I open the cabinet door. In your case, I would hinge the lid which would allow for airflow.
I'd hinge it on one end, then a prop depending on the space available.Yeah, that's a good idea. Maybe use a bunch of plastic bushings to elevate the lid 1/2".
Yeah this is 3 season camp, the batteries come home with me and spend a cozy winter in the basement. 8s 280 case has a fair amount of gravity to it, def the max I’m swinging around.I'd buy the 16S Luyuan box and make it a parallel 8S 560Ah box with a pair of BMS's. Of course if you don't intend to carry it.![]()
Any updates getting JK inverter BMS working or communication with Sol-Ark?I'm ordering one of the JK inverter BMSs (JK-PB2A16S20P) for $109 with the front panel and the inner compression/BMS panel both for $19.
Since it turned out my regular active balance BMSs are so old they don't work with the displays in the cases I already have, I am also ordering 3 active balance BMSs (B2A24S20P) for $108 each. Air shipping is $89 for everything
In the future, I may convert all of my batteries to use the JK inverter BMSs but I don't think anyone has them working closed loop with the Solark yet. Using multiple JK inverter BMSs closed loop isn't working yet either.
This is a never ending project and I love it.
Those that have added heaters, where did you put them? On the bottom or center side seems like the only options for heater pads? As with all other premade boxes doesnt look like theres anywhere you could insulate unless you go outside the box. Though putting the epoxy fiberglass sheets in between a heating pad and the metal case would probably help a lot in prevent thermal transfer loss there at least.
