42OhmsPA
Who likes Electrical Gremlins?
Is that a 3D printed fuse holder?Class-T on front plate.
What’s the second small gauge wire on the positive terminal?I was finally able to finish assembling mine. Here's some pics. Took me a while, things to do etc etc. Also, I had to swap around the cells because I mixed up main battery positive and negative.
And I wanted a t-class fuse inside the box, preferably before the breaker. After much consideration, I decided to put it on the front plate. Taped a few of the BMS temp-sensors to several spots/cables.
I noticed there's a bit of voltage drop between battery pos/neg compared to the box terminals, perhaps I should use some paste on the class-T connections as well. How much voltage drop do you lot deem acceptable?
Empty rows in the box.
Some cells!
First attempt, but having positive and minus mixed up :-(
This is better.
The front from the outside.
It fits.
Angle from the other side.
Yes, only need one. I prefer the light bulb over a resistor. And it looks cool.I would simply make a single precharge at your inverter input. Why put one at every battery? Seems redundant, added unnecessary cost.
Unless I misread something.
It looks cool too when you press the button.I had good results using 48V forklift light bulb as my precharge resistor.
If one doesn't have a 48V bulb, a few 12V in series can be used or even an incandescent bulb normally used on 120V AC. The nice thing about using a bulb is even a person with very little knowledge about the system can understand pushing a button until the light goes out, then throwing the main switch.Implementing the light bulb solution is so easy. I wanted a resistor solution but I couldn't figure out which resistor. People were posting which resistor to use for a 12 volt system but I couldn't find the right part for a 48 volt system.
It would be fairly easy to switch to a resistor. Maybe someday. The light bulb does provide good feedback for when the capacitors are full.
When a 20-40-60w 120v ac incandescent bulb are so cheap why wouldn’t you just chose something so easy to grab rather than a DC bulb?I found a 24 volt bulb that I can use for my 8s portable system. Add a couple of wires with clips and a bulb holder and it lets me precharge my Multiplus. The bulb is only on for a moment or two so it doesn't take long.
I used this for my portable system in the past since there is only one battery and it is a non inverter model. Since my main system has multiple batteries, I don't bother since there is plenty of input and they utilize the JK inverter BMS which has precharge built in.
Biden got rid of all those bulbs. I cant find any besides "appliance" bulbs.When a 20-40-60w 120v ac incandescent bulb are so cheap why wouldn’t you just chose something so easy to grab
Valid point. As it turns out, didn't cost much and the jumpers have paid for themselves with other DIY projects. Other benefit is that I can run it directly off the battery if I want to add light to the solar area.When a 20-40-60w 120v ac incandescent bulb are so cheap why wouldn’t you just chose something so easy to grab rather than a DC bulb?
The process of banning them actually started in 2007 and most of the world has also banned them.Biden got rid of all those bulbs. I cant find any besides "appliance" bulbs.
still available in Japan! Daiso and DCM both still stock!The process of banning them actually started in 2007 and most of the world has also banned them.
Those bulbs will work as I mentioned but take up more room if a permanent install.When a 20-40-60w 120v ac incandescent bulb are so cheap why wouldn’t you just chose something so easy to grab rather than a DC bulb?
Those appliance bulbs would still work fine.Biden got rid of all those bulbs. I cant find any besides "appliance" bulbs.
No, it's 3D printed cover though. I ordered T-class holders with 2 terminals, cables directly on fuse, as they are smaller, but they come without a cover. Have one cover printed in the camper as well, printed plastic threaded nuts to hold the cover in place as well.Is that a 3D printed fuse holder?
Power for the BMS.What’s the second small gauge wire on the positive terminal?
You have a link where you ordered them from?No, it's 3D printed cover though. I ordered T-class holders with 2 terminals, cables directly on fuse, as they are smaller, but they come without a cover. Have one cover printed in the camper as well, printed plastic threaded nuts to hold the cover in place as well.
That would be a Dutch website ( https://accunoord.nl/nl/accu-access...t-zekeringen/vte-class-t-fuseholder-225a-400a )You have a link where you ordered them from?
Looks like mine are on the way too! I had Amy customize mine with just the cutouts needed on the front for the comm board - I'll make my own holes for the power connectors.... as soon as I decide which ones I'm going to use
Yes, DDP.I take it we all paid DDP?
Any word on recent changes requiring additional payments?
I dread to ask, lol.Yes
Yes, DDP.
No word on additional payments….yet..
