Hello,
I have been running a single LV2424 for about 3 months and this week added a second unit. I would like to run them in parallel to power to an AC distribution panel in a single phase. They are both set to PAL, with one as slave and one master. Each is connected to 2.2 kilowatts of solar panels.
I have wired 2 20 amp 120 volt AC circuits for these two units as grid backup for when solar and battery are insufficient.
Everything appears okay except the first unit is now unable to draw from my AC as a backup as it previously had. Whenever i connect the AC input to the first unit it blows the 20 amp breaker immediately. This unit had previously been running solar with AC backup with no problems. The new unit, unit 2 can be plugged into either AC circuit and will draw power normally as needed.
Any idea what is going on here?
