Darren Orange
- Feb 25, 2021
- 74
Hi,
I have a LV5048 and it has been working great for almost a year now, however I only recently got solar panels. The panels are running typically run around 80V I have a 2S5P setup for this for a total of 4kw or 400w a panel. This is on solar input #2, nothing is on solar input #1.
Let me start with this my batteries are not fully charged around 53V out of 57V battery size is about 13.5kWh. It has started charging the batteries as is normal and running our house as well off the solar panels.
So I've noticed something strange with the solar today such that it is pulling more power up to a point from the solar array when the load goes up. I was able to test this with a microwave. I figure I might have a setting wrong or something.
I know that it is showing my load is almost matched to my PV power at the moment I added my car as a load to pull more power to max out the power from the array but if I disconnect the car the power output from the array will drop ~300 watts and its about noon. Maybe I'm wrong but something seems a bit weird?
Thanks in advance for any help.
