The batteries are new Jakiper 48V 5U with the same BMS as SOK and Jakiper PRO. So I think
the problem presented is general to all the PACE-IC BMS P16S100A.
With BMS coms enabled and working, the master LV gets is battery parameters #6, 27, 29.
The problem I am having is the values for charge and float are too high, both are at 57.6V.
This charging voltage is causing a severe top balancing issues on some of the packs.
I see 300 to 400 mV difference in the cells near the end of the charge cycle. Some
cells are peaking over the 3.9V cut-off which fault the entire pack out of service.
The BMS has a very slow reacting balance bleed which kicks in (Balance Threshold) at 3.5V during charge.
But this does little to slow the eventual over voltage build up, especially when there is a sizeable
charge current coming in.
If left disconnected, the OV cells settle down. I assume the pack will re-connect its output when
the OV cells falls below the OVP Release (3.45V).
Is the solution to use USER and manually pick a good charge and float which will keep the cells
from over volting on charge?
How reasonable is it to assume that 16 cells will remained reasonably balanced over
time?
time?
