priorityelec
- Sep 11, 2020
- 37
I have a new LV6548 and 2 EG4 batteries hooked up. The battery percentage is all over the place and is clearly not accurate but the batteries are able to fully charge just fine but the bms is stopping charge. I really want the inverter to stop charge just a little before the BMS. And I want the inverter to shut off the batteries and switch to utility power on its own...not wait for the batteries to die.
In the watchpower phone app I have the following settings:
--Bulk Charging Voltage 56.8
--Battery Cut Off Voltage 47.0
--Float Charging Voltage 54.4
Right now my batteries are fully charged up and sitting at 54.4 volts but the app on my phone says they are 72% charged. The actual inverter battery percentage bars show they are charging at 3 bars. The batteries themselves show 4 solid SOC lights.
Also, as they're charging, the batteries make their way up to 56.8, the app shows 100%, then they settle down to 54.4. If i turn on an air conditioner the voltage drops and my battery percent will start showing somewhere in the 60% range...but I know they're fully topped off.
What am I doing wrong?
