I have two LV6548s in a Split Phase configuration (Basically followed Will's Setup). Right now I only have PV of 2.2kw connected to the first LV6548 (one input). I also have a 15KW battery connected.
Issue: On multiple occasions when I run something that has a large startup power need (Table Saw, Vacuum, Spray Painter, etc) - I receive a F80 Fault on the Inverter that has solar attached. I tried connecting the PV to LV6548 #2 and then got the fault on that one.
Has anyone come across this issue? Any thoughts or ideas appreciated.
