davesmith87
- Sep 19, 2021
- 18
Hello all,
I'm having an issue with my pair of LV6548 inverters not recognizing my battery.
I've got (2) 24v 100AH Ampere Time batteries (https://www.amazon.com/gp/product/B08P6LP1J9/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1). These are wired in series (to get 48V) then connected to the inverters.
The inverters are giving a BP warning (which according to the manual is Battery Disconnected).
Settings Below
Option 5 = User Defined
Option 16 = Solar and Utility
Option 26 = 56.4V
Option 27 = 55.0V
Option 29 = 48.0V
The 1st night I had this hooked up, it appeared to work as it should. With option 1 set to SbU (solar then battery then utility), I could see it working. At night the load was coming from the battery, and the grid was charging the battery as well. I didn't think that was very efficient (just cycling through the battery), so I programmed option #16 to only charge the batteries off Solar. Well I don't have all my panels setup, so my load was always more then what I was producing so the batteries didn't charge.
Now I've changed setting #16 back to solar and grid and the batteries are just not charging. With a volt meter, I have tested that the wires are hot.
I feel like I must be missing something simple.
As a test, I also removed the Fuse / Shunt. Got the same results. Added them back in. Not sure how to troubleshoot at this point.
I think the battery is completely dead, and the inverters are not recognizing it to charge?
Settings Below
Option 26 = 56.4V
Option 27 = 55.0V
Option 29 = 48.0V
