I have most of my supplies and planning my install of two LV6548 inverters to power my house. But am a bit confused on the grounding line coming from utility. For utility power IN on the two 6548s, do I use the utility ground, or my own earth ground I will be using on the AC power OUT to my load panel in the house and just hook up the load and neutral lines from utility? I cannot seem to find a clear cut answer when I search, and the LV6548 manual doesn't really make that distinction. Thank you in advance.
zack
zack
