yellowjeep2850
- Aug 18, 2021
- 18
hi I'm building my first system , and I'm using two of the mpp-lv6548 it says 4000 watt max per pv input . i just want to check my reasoning to be sure i do this right. when i use midnite solars calculator , i can get close to 4kw with 4 - 480w panels in series @ two parallel strings per pv input 3840 total each , so with all maxed out with the 4 total pv inputs it puts me at 15360 , does this sound correct ? i put in the applicable temperatures for my area so the max of 250vdc won't be reached , results are attached
i am always second guessing myself , everyone's input will be appreciated cheers!
