"It's odd that it works fine in SBU with utility turned off, correct?"
humm now that you mentioned, i remember that i had post something to the MPP support once, time ago.., i will look into my mails and post it here, after posting this comments.
"Have you already tried the battery voltage calibration, I linked above, in the past?"
No, i havent, but unfortunately, when i was about to start with the instructions to factory reset, windows 10 just did an upgrade half an hour ago, after my previous post, and now, even the usb for the solar power app, is not working.
source Universal Print cannot be found.. Im trying to find a newer driver somewhere now.. but i will post my comment to MPP Solar in a few.
Thank You for all your help..
This was the email comments i have sent to MPP Solar Support about this situations:
1st:
"I cannot remember if i have gotten this error ever. I do remember error code [08] and some bus voltage high or something like that.
Thats only when manually open the circuit to let the 125-127VAC from utility be present, or when it comes automaticly after gone.
But, since that is happening, i mostly used manually. Its like when utility comes into scene, there is nothing to do, because of the settings doesnt need to power or charge anything, cause there is battery and there is solar.... just to be there without doing nothing... just present, but its starts to bump bump with the transformer and at the end, restarts it self.
Hope this helps.
Thank You"
2nd:
"Something interesting, i let the battery go to the 46V and wait for inverter to shutdown the power to the house.
Then i started the utility to re-charge the battery, its night time, so there is no solar panels, only battery been charge with utility.
When battery percent reached 53V and battery percent reached 53% both around same time, the inverter started to complain and buzzing trembling like always.
Note that setting were in 01 SBU. I rapidly disconnect the utility input and changed the parameter 01 to SUB and connect the utility after that, and the problem of buzzing or trembling didnt repeat. So i dont know what this tells or says, but in case it server or been of a help..
Battery is still charging...
Thank You"
