Lynx Distributor modified bus bar wiring ok?
Gurusi
Hey, I am currently putting together a schematic of my build (see PDF attached). I am looking for confirmation of if it is ok to wire my split phase LV6548 + and - to the external bus bar post (see jpeg) or whether i need a terminal doubler? I know with a standard bus bar you can put two lugs on one post (highest Amp first)
I am also unsure whether to use a 58V/250A or 58V300A mega fuse?
This is looking like a more cost effective build compared to two blue sea 600 AMP 4X3/8-1 with covers.
Thanks!
https://ibb.co/6BkNzXL
image link - jpeg was too big to upload
  • array build lynx.pdf
I suggest you use a lynx power in instead of a lynx distributor.
modify two branch positions to be fuse-able using this guide.
Fuses protect wires so for pure copper 2/0 wire in free air with insulation rated for 90C or better use a 300 amp fuse.
Since the batteries are fused at source connect one battery to each end of the backplane and the other two to the un-fused branches.
The AIOs get connected to the fused branch positions.
Thanks for confirming, I will go with 300Amp.
Yes the linked video got me interested originally. I am still divided whether to save $100 with the "power in" model and not having the fancy led lights for a blown fuse.
Could you confirm if its ok to hook up the x2 inverters + & - lugs to the large terminus on the side? I will be getting it inspected and don't want to fail and have to replace/adapt. Im guessing i am overthinking it, but want everything to be correct.
Your method, which I suspect is cribbed from
is fine by me.
I don't know what your inspector will or won't accept.
is fine by me.
The video attached is new to me (and a good idea). This was my wiring idea:-
Apologies my editing skills are basic.
You don't need or want fuses at the lynx for the battery circuits.
Those are fused at source.
That is why I suggested you connect 2 batteries directly to the backplane(one on either end) and 2 to unfused branch positions.
Then fuse the last 2 branch positions for the the AIOs.
Ah ok, yes it just clicked thanks. My initial plan was for additional redundancy on the batteries at the same price as a decent bus bar, but your suggestion would give protection for the AIO's.
Thanks for the help
