I also did buy 2x 48v packs from Treeline Power Systems, and was generally satisfied with price/quality and whatnot. The only thing I didn't like about these packs, was later I decided to build my own battery clamp assembly (using aluminum plates), and Treeline had used that double-sided sticky 3M foam tape to stick all the cells together, and it was total PITA to pull those apart and clean all the gooey stuff of them with Goo Gone so they would sit flat against each other. Had I known about that, I would've called them before shipment and requested to have them just send the cells without the sticky tape on them.
I also wished the BMSs had been managed ones so I could read cell voltage (I do like that they are rated at 200a though). I wound up buying a set of 2a active balancers to wire up along side, because they have bluetooth and I could login and check voltage easily.
This is more reason why I like idea of piecing together your own pack, because then you can get the exact BMS with the features you want. On the next pack, I think I will just buy the 200a JK BMSs, with bluetooth and relay controlled...
At any rate, I did like that the Treeline Power Systems packs shipped fast!
