M6 Bus Bar Terminal Hole Size.
A.Justice
Swears he didn't start that fire.
TN
I just got the 25ah TopBand cells from BH, and am going to make some bus bars. The stud is M6.
Should I drill 6mm holes or 6.5mm? I don't have good metric bits, so I want to buy the right size, the first time, on Amazon.
Thanks in advance!
time2roll
Photon Sorcerer
I recently used a 6mm bit and the 6mm screws go through but they are tight. For a bus 6.5mm might be better. You can always go larger if needed to readjust.
