Been reading these forums for a while but this is my first post. I recently purchased a Magnum Energy MS4024PAE with the following:
PT-100 Charge Controller
ME-ARTR Advanced Router
ME-BMK
I reusing my battery bank from my last system (24v ~ 13kw)
My old inverter I could put it in battery priority and turn the internal charge controller off so once the batteries dropped below 23v the transfer switch would atomically put the inverter into bypass mode. Then once the MTTP charge controllers charged the batteries back to 27 volts it would switch back to inverting and turn off bypass mode.
My question is can I do something like this with the magnum set up? I want it so that when the batteries drop below 23v the system switches into bypass mode and doesn't charge the batteries with the built in charge controller.
My old system did this flawlessly and you wouldn't even know it happened (TV's and other electrical devices wouldn't notice the switch). I'm upgrading as to stack inverts. Will be ordering another inverter once I know I can get this running the way I want to.
Thank you in advance
ME-BMK
