SenileOldGit
- Oct 15, 2022
- 375
I have 12kW of solar panels, and two 5kW Voltacon V7 inverters in parallel, and three 5kWh Pylontech batteries. My house has mains gas and mains electricity. My daily standing electricity charge is around 65p, my daily standing gas charge is 30p. Apart from two occasions in the past four or five months, I have used zero grid electricity. I am trying to work out whether it would be cheaper for me to go off grid for electricity, and keep my mains gas supply, and use the mains gas to power a generator in the Winter months on the occasions when I don't get enough solar that day.
I have a cheap (£70) petrol generator which I bought from Aldi online a few years ago, which I might be able to use with my inverters, if it turns out that I am able to generate enough electricity in the Winter most of the time, and only need a generator a few times a month. (I haven't gone through a Winter yet with my solar system working properly, so this coming 2024 Winter will be the first set of proper figures I get from my solar system.)
If it turns out that I need fairly frequent (three or more days a week, for at least a month) of generator electricity, I was considering buying a better generator, and I am wondering if you can run one off mains gas in the U.K.?
a) Does such a generator exist in the U.K.? I haven't been able to find one - all I can find are ones that run on propane, and I believe the air/gas ratios, and other things, are different, for propane, compared to mains gas.
b) Will a qualified gas fitter be allowed to/willing to extend a gas pipe round to the back of my house, and into the generator? I presume outside gas pipes are orders of magnitude less dangerous than gas pipes inside a house (zero risk of an explosion), but I don't know what the legality of this is.
I only ask because if I did need to use a generator several times a week, if it isn't on mains gas, I would have to get gas or petrol to it on a frequent basis, and this will be very inconvenient and I presume more expensive than using house gas.
Because I have 15kWh of Pylontech batteries, I don't need a powerful generator, 1kW would be fine.
