Hi Sverige,
have you got skills in soldiering and would you feel comfortable in setting up a programming environment?
If yes, I am currently working on my ESP8266 controller program to retrofit real MPPT functionalty to many <10A cheap solar controller modules that only provide manual power point trimming.
My current DIY system provides a full graphical battery monitoring, tracking, statistics.
While I am on the way and have a few digital outputs left over, I could provide control for two additional buck converters with enable function,
so I could also remote/programm-switch these power outputs to reduce power when not in use.
The current bill of material will be:
- your small pseudo-MPPT solar controler (cannot be a PWM-module) e.g.
MPPT solar controller battery charging board
- a
Wemos ESP8266 WiFi enabled microcontroller
- an
INA226 I2C bidirectional current/power monitoring sensor
- 1 to 3 or more buck converters with enable input
- alternatively, if you prefer to switch AC a
2 Relays board
- 6x4cm or bigger
prototyping board
- a few resistors, wires, screw-terminals and a small industrial junction box.
n.b: I am not affiliated with Aliexpress and do not even recommend them, but their shop provides almost every device's pictures and details to describe what's requested.
Stay tuned, I'm on my way...
