Rednecktek
Expert Newbie
Ok, I've double and triple checked my numbers, re-done my equasions, and... is this right???
Ok, so the project is to make a rolling tool box solar generator with enough oomph to power an RV's 30a shore connection for a week, OR run my wire feed flux core welder and grinder in the field.
Basic parts list:
PowMr 3.2kw 24v AIO (Ordered about 3 days before the 3.6kw came out, Doh!)
Harbor Freight Bauer Modular Toolbox
JBD 8s 100a BMS (From the CC sale)
Eve 230ah cells
MRBF fuses, AiLi shunt, outlets, portable solar panels, Anderson jacks, breakers, fans, etc.
Here's my quandry; converting the metric measurements for the cells into 'Murican...
An 8s pack would be 174mm wide, 432mm deep (8×54mm) and 205mm tall plus posts. In 'Murican that would make a pack 6.86" wide, 17" deep, and 8" tall.
The Bauer toolbox says:
So 3 packs of 8s would be 20.58" wide, 17" deep and 8" tall, right?
Can I actually do a 3p battery set in there?? 230ah 24v would be 19.5kwh of battery capacity?
My plan is to build a plastic shelf over the top of the batteries and lay the AIO on its back, DIN rail breakers next to it, all the bus bars and fan controllers. There should be plenty of space if I put the AIO against the hinge side, right? 120mm intake and exhaust fans will be on thermostats.
Can someone please check my math and all on this? Am I going to get bit by physics?
Basic parts list:
Eve 230ah cells
