Hoop33
I have a Rover 100 charge controller. I use the app to monitor the controller. In the top right corner of the app you can access the settings and history. Under the history, you can see the readings for different things about what the system is doing daily. My question is about "Max Battery Volts". I will use September, for example. Out of 30 days, most of the days say the Max Battery Volts is 13 volts to 14 volts. There are three days that have a different reading. One day is 32.4 volts, another day is 31.5 volts, and one more day is 20 volts. Here's my question. Why is it, on random days, the Max Battery Volts are spiking to these high numbers and is this a dangerous situation when the battery volts spike? Is it doing damage to the battery? Is there a potential for a fire? I have several fuses and breakers to protect everything. Still, I don't want to burn down my barn. Thanks in advance for your help.
