Hi,
i have a 5kw inverter. I would assume that I would get solar panels that W add up to 5000W.
However the hand book is saying:
it is then cosidering 250W panels:
Now what i dont understand is in both of their recommended set ups has a total of 12 panels, so 250w times 12 is only 3000W.
How will that help me cover my needs if I want to use 5kw off grid?
INVERTER MODEL | VM5000 |
Max. PV Array Open Circuit Voltage | 145Vdc |
PV Array MPPT Voltage Range | 60~115Vdc |
Maximum Power (Pmax) | 250W | Reccomend: |
Max. Power Voltage Vmpp(V) | 30.1V | 1. 2 pieces in serial and 6sets in parallel OR |
Max. Power Current Impp(A) | 8.3A | 2. 3 pieces in serial and 4 sets in parallel |
Open Circuit Voltage Voc(V) | 37.7V | |
Short Circuit Current Isc(A) | 8.4A |
