Hi,
I'm located in Idaho and our provider is Idaho Power (IP). They limit the system output to 25kw based on
the "label" on the inverter. I'm considering using micro-inverters so I believe IP would use the max output
of each inverter. Looking at the Enphase IQ 7 it's max output is 240 VA or 290 VA depending on model.
Questions:
1) Is the 240/290 the same as "watts"?
2) Do I want to select panels that are as close to the max inverter input value so that the max output is generated
and I don't "waste" available watts?
3) How do I determine what size panel would result in the max inverter output?
Here's a link to the Enphase datasheet. https://enphase.com/sites/default/files/downloads/support/IQ7-IQ7plus-DS-EN-US.pdf
Victor
Questions:
Victor
