I am interested in maximising the cell life of the EVE and CATL cells as close to the maximum possible, this means i have to maintain compression at the beginning for the first few cycles, to make sure that no voids appear and we are setting the cells up for a long life. I am also aware that the cells will expand and contract over time (increasing as the SOC changes and cell cycles increase).
I have some assumptions that I would appreciate to be clarified or debunked
- We should have the 300 newtons of force on the cell for the first ~5 charge discharge cycles to help with cell forming and thus extends battery life.
- we only need the FR4 for electrical isolation, the EVA or poron can achieve isolation.
-there is a potential issue that EVA foam can deform and not 'spring' back, providing a potential void.
- having all the cell just clamped together with steel plate is bad because it doesn't adapt to the cells changing SOC and cycle life, meaning internal pressures can drastically increase over time.
- using calibrated springs is theoretically the best option but is over complex and you still need EVA/Fr4 for electrical isolation?
so the best option is official Poron, or EVA foam (not ebay). that can handle the consistant compression at least for the first 10 or so charge and discharge cyles (until the cell has formed in its best state). then the foam has done its job to a certain extent and can deform with the cell as it expands over time?
- is there official documentation from the cell manufacturers on how to assemble these packs , there must be up to date documentation on this to use their products properly? (i cant find it anywhere atm)
thanks!
thanks!
