Bottom Line:
Looking for options to extend run-time (on an Inergy Apex when recharging isn't an option*) of an Alpicool 12/24DC/110AC 26 quart portable fridge. My goal is to be more or less operational with lights, internet, video, battery recharging and refrigeration for at least seven consecutive days.
Background:
After experiencing three week-long power outages over the past 10 years, reality has taught me that "prepping" is no longer just for off-gridders. So, a coupla years ago, I got an Inergy Apex solar charger (with two external lithium batteries incoming....so the Inergy folks keep saying..) and, to weather the next storm(s), a bunch o' DC- and/or efficient AC-powered gizmos—small AC TV/monitor (runs on ~11.5 watts), Blu-Ray/DVD player (runs on ~5 watts), TV antenna (0 watts), RaspberryPi 4 (runs on ~4 watts), portable washing machine/spin drier (runs on ~225 watts), hand-held Ham radios (run on rechargeable batteries), battery-powered "smart" fans (run on internal lithium, USB and/or six D cells) and battery-powered/oil/kerosene lamps, oodles of rechargeable AA, AAA and D batteries, Berkey (runs on gravity), et al.
What I've done for the Alpicool testing (the Alpi' filled with pre-cooled 1/2 gal milk, eggs, butter, flour):
I've tried...
- Running the Alpicool on both Max and Eco mode (Eco runs slightly longer)
- Running from both AC (converts 110 AC to 14.5DC) and DC (via the Apex's 12V cigarette lighter outputs) (unsurprisingly, DC runs ~twice as long as AC)
- Placing a coupla Techni-Ice packs in with the food (definitely helps reduce compressor usage)
- Surrounding 3/4 of the Alpicool case (top/bottom/sides) with Rmax R-Matte Plus-3 (two-inch hard, thermal foam with an R value of 12.5) (0 effect in extending run-time!)
- Installing a 12.2V DC-DC regulator between the Apex and Alpicool (although it DOES maintain Alpicool at 12.2V (when Apex is < 12V), 0 effect in extending run-time)
- Covering the Alpicool with a thermal cover from another portable fridge (seems to add a coupla hours to run-time)
- Finally, I'm currently mucking about with a mechanical timer to switch the AC power on for 15 minutes each hour (i.e., 45 minutes power OFF)
To date, however, the best I can do with the Alpicool powered by a fully-charged Apex (via DC and in Eco mode) is ~52 hours, assuming I don't open the fridge or run anything else from the Apex. So, even with the additional two lithium batteries (if/when they actually show up), I'm still only eeking out about six days of run-time....and that's running ONLY the fridge and nothing else. Sitting in the dark for a week with a nice, cold glass o' milk and a stalk of buttered celery doesn't quite cut it.
Anyone have experience extending an Alpicool running on batteries by DAYS rather than a few hours?
* Currently, reside in a small rented flat in an area where techie-looking thingys (e.g., PV panels) tend to "walk-away" when not under constant/direct supervision. So, although I've got a few PV panels, being able to implement them in public areas in an emergency is risky business.
Background:
I've tried...
