GrumpyOldRetiree
- Jun 12, 2020
- 24
I'm getting ready to hook up solar panels to my MPP Solar PIP 1012LV-MS AIO.
The following specs are listed in the pdf I downloaded:
Max. PV Array Open Circuit Voltage = 102Vdc
PV Array MPPT Voltage Range = 15~80Vdc
I'm a little confused about the MPPT Voltage Range...
Does this mean that if I put enough panels in series to get the array voltage > 80Vdc (but less then 102Vdc) that the MPPT mechanism will cease to function?
Or that any array voltage over 80Vdc will be "wasted"?
Or...does it mean something else?
I am aware of of the meaning of panel open circuit voltage and the need to "de-rate" the array size to accommodate cold weather, so please skip any explanations of these factors unless they directly relate to the question at hand.
I have googled this subject and only found vague descriptions of the term.
