picked this up today. Normally priced @ $1400.00 CDN. store clearance for $980.00. Pretty happy with the purchase thus far.
couple questions about the generator itself:
1. Air filter…. How to oil? (All my small engine stuff either has no filter (snowthrower), or a paper throw away. We have a Honda at the cabin but my (deceased) father in law always maintained it. So I’m new to foam filters.
2. Oil. Factory stuff is conventional. 5 hours then change (break in). A small engine is a small engine right? I use amsoil “small engine” synthetic 5-30 for all my stuff. Supposedly has higher zinc. Who knows? (I used to use plain old synthetic 5-30).
what are you guys using?
now just wondering (not sure if I should post elsewhere) what output to use? 20A, or 30A twist?
im 99.99% sure I will be buying a Victron multipluss inverter/charger. The plan is to build a diy “ecoflo” type power box for our cabin. I will be using my champion to charge it up.
in the off season (winter) the power box will come home.
im undecided about 24v or 48v but either way it’s 1680 watts of charging. (48 x 35, or 24 x 70). Unless I’ve calculated wrong i should be pulling under 20 amps of ac to do this.
the genny has 20a outlets, and a 30a twist. wondering what type of plug to put on the Victron?
if I put a twist, then I can only use the generator to charge, but a 20a plug I can plug it in at home.
also wondering about the bonding? It’s a floating neutral. The Victron is bonded to neutral, but when it receives power it looks for the neutral from “shore”.
the power box will be on a handcart for now, and the cabin “plugs” into it. (Cabin is on one circuit).
there is no grid, no ground rod, no electrical panel. Cabin is wired up, and terminates to an extention cord that plugs into the generator (and my power box when built).
our current Honda is floating. Victron will be bonded when inverting. Thoughts?
