robbob2112
Doing more research, mosty harmless
I’ve shared that the cells do seem to support it. See specs just posted.
The way I read it is they recommend 0.5C per cell for max longevity of the cells with it being allowable to run 1.0C if you need to... You have 2 cells in parallel to build it so you are actually running 0.75C per cell -- so no damage
Here’s some pix that were requested. Noticed that crimp sort of overlaps one another.
Getting the shrink wrap off the lug was a long process and it had melted badly.
YIKES - those are the fold over tab style ... they just press and hold but never really cold weld as enough force to do that would also deform the tabs and make them solid... with them lapped like the are just a bad job by Chins all around on the cables.
Here’s cables I’ve replaced with.
Notice that this brand recommended by many forum members for its flexibility has same melting temp as smaller ones that melted. Should be fine.
2 x 2/0 -- each 175a using a conservative chart --- 325amps using the windy nation 105c chart. --- either way 2 of them will more than carry the amps without getting warm.
Good job getting all your issues fixed... .
p.s. I did warn you to measure what length you needed on the grub screws --- 25mm is approx. 1in... --- the holes in the batteries are typically only 5mm deep
And we do appreciate you putting your problem out there for the world to see ...
And now I will go open my repacked wattcycle 300amp battery and re-do the cabling --- it didn't occur to me until this thread the wire lapping back on top of itself would be an issue.... I probably wouldn't run in to it until I had a failure.
