The bummer is that the op was warned about what the
realistic specs are back in April on another thread.
Tip: Treat the Miady's like TalentCell LFP, which have the specs printed on the case. If you do, you'll be fine.
@MrPhoton - stop torturing the Miady's.
Perhaps contact Miady and also Amazon, not just for replacements to torture over again with new videos, but to get them to correct their mistaken specifications. It may all be down to a decimal point.
In fact, looking at the spec sheet for download here for the 16ah, I think they are missing a decimal point, or it is hard to read. So instead of hitting them up with 42A max, the more realistic value should be 4.2A, which jives with their recommended standard charge of 0.25C as seen on the sheet.
I also see the 80A pulse charge (3 seconds max) on the 16ah batt. That HAS to be wrong.
These specs are obviously wrong, and MrPhoton is proving that by repetetively smoking Miady's on both charge and discharge.
I wish I could find a contact for Miady to inform them that these specs are not realistic. If anybody knows, lets do the community at large a big solid to get them to correct it and stop the abuse.
