thescoutranch
- Jul 13, 2022
- 25
These Micro inverters have the capability to have 2 panels on the input and a single output. What I am trying to figure out is can you use them with just one panel and cap off the other input. If so, what would be the max input that It could handle?
The spec sheet states:
Input
“Recommended Max PV Power (Wp)
450 x 2”
Could you use a single 600w panel, and it would be able to handle it? I am not sure that 600 W panels even exist, just hypothetically speaking.
I called their technical assistance line and talk to a gentleman who assured me that you could do this and it would not be clipped going into the inverter.
I do understand the power coming out of the inverter would be clipped but that’s not an issue for this question.
I know what the tech-support was telling me, but I wasn’t sure if he’s just telling me what I wanted to hear or not.
(Ie the spec sheet state max input watts 450x(2) while the manual states
Max Recommended PV Power(Wp) 340 x 2, he stated this was probably an old table in the new manual, which I believe)
Does anyone have any information on using these micro inverter in this type of configuration?
I assume these inverters would be cheaper to build if they inverted the feeds together, not separately.
Thanks for any replies
Epp
Input
450 x 2”
Epp
