Oh, I tried plugging in LAN and Wifi at the same time and noticed that both interfaces got an IP address and was reachable. I was half hoping that LAN connection would disable WiFi to give the weak BT signal a little more chance because BT is on the same 2.4G frequency band as WiFi. I didn't try blocking the WiFi connection but good to know,
Ah, I know how the LCD would look but not for mine. Sounds like the LCD polarizer had some damage so hopefully that can be resolved by just replacing the display components because taking off the entire inverter is a PITA.
Another problem I have been monitoring and watching is the poor performance of the DC MPPTs. I was hoping others using the MN15 could collect some data on the MPPT and see if my observations line up.
Green is my AC coupled (via AC coupling breaker) 7.5kW Enphase micros facing the east and Yellow is the total PV production as reported by the MN15 inverter. It looks like the software will add up the AC coupled solar as part of PV production so Yellow - Green should give me the Blue curve which is the DC solar directly attached to the MN15.
Today we pretty cloudy but there are times when the enphase did decently but I can't say the same for the DC solar. Frankly, it's pretty pathetic and I have been monitoring this for weeks, pretty pathetic with lots of periods where there is NO production. I am using two MPPTs with the 8 strings of REC260W panels configured for around 270V so they should be well above minimum MPPT range.
