balikbayan21
- Jan 17, 2021
- 23
I ordered parts almost identical to those in the milk crate battery video
I ordered 4x 105Ah LiFeP04 cells and a 12v 100A LiFeP04 Daly BMS, the Bestek 500w inverter, a 0-48v DC charger, an Alibaba 10a 12/24v MPPT, a bus bar, a fuse block, and a set of usb ports.
I had magic smoke and the inverter died (source of magic smoke), I think I know why but would love input before I wire things back together.
Here is what my BMS/Battery looks like, it matches the diagram sent and I've watched battery build videos so I think I got this right.
Here was the layout originally, I didn't like how slowly the battery was charging. I set the AC-DC power supply to output either 24v or 14.6v, connected that to the MPPT (in the PV input), then the MPPT connected to the battery and bus bar on negative side. Battery would sit around 13.5v for what seemed like forever, so I got impatient.
I was thinking that the MPPT might not be passing power to the battery and that because the battery voltage wasn't increasing, the answer was to bypass the MPPT... so I did:
My first clue that things weren't right was that the voltage readout on the power supply (AC in, DC out) was no longer adjustable. It simply read the voltage of the battery. I let the battery charge and after about an hour there was a pop, smoke, and I quickly disconnected the negative lead from the battery to the BMS.
I'm fairly confident that going back to include the MPPT is the safe answer. I also picked up a shunt to display voltage in/out.
I'm very open to input and don't want to re-assemble new parts until this is sanity-checked.
Appreciate you all reading this.
