InMyImage
- Nov 17, 2020
- 146
Hey, so my head is a bit dizzy from trying to figure thus out right now and have had some unexpected expenses pop up so I need to quickly figure out the absolute minimum devices I need to get my Multiplus II 3000/2x120 inverter setup and running with my Lishen battery packs that each have separate BMS’s. Note that this is the model designed for 50amp RV’s so I don’t need any special transfer switches or other gizmos specifically to get it to work in my RV, I just need to get the Inverter configured and able to monitor the system including at least approximate battery SOC.
Other than the obvious cutoff switches, fuses, wiring, etc, I think I can get away with just the bluetooth dongle and a shunt, but not sure if I need the Victron Smart Shunt since I’ll have access to system data using bluetooth via the dongle.
I am not interested in any additional control or monitoring panels inside the RV. I’ve had an inverter setup that came with the RV for maintaining power to our residential fridge and barely ever look at the panel. However, if anyone knows if I can use my existing Xantrex Freedom X panel with the Victron Multiplus, I’d appreciate knowing.
Anything else anyone thinks I need let me know and please include info on what and why it’s needed.
Thanks
Thanks
