Hi All,
I am planning to install rigid solar panels on flat roof already coated in silicone. The roof has plywood, then thick layer of tar (it used to be tar and gravel originally) with several various coatings: asphalt emulsion coating, another acrylic coating that prevents yellowing of silicone, and silicone on the top.
The roof has slight angle, and there are little bumps all over.
Silicone coating does not get warm at all to touch. Maybe little bit when temperature reaches low 100's which is max for my hometown.
Now, I want to install rigid solar panels on the top. I read there should be least 3 inches of separation between panels and roof surface for heat disipation. Is this true, and do I have to consider this given my roof surface never gets hot thanks to silicone?
I have to position panels at 45 degree to the roof orientation to make them face south. I would like not use rails that touch roof surface because it will disrupt rain water flow, and maybe cause ponding.
In my area, we can have lots of wind upto 80, 90 mph, so I would like panels to be as low as possible. My roof has parapet walls that should provide some protection from wind. However, I read there should be some small angle to prevent water ponding and dust getting stuck on the panels' surface.
What would be a simple mounting system that provides small tilt to solar panels on silicone roof? When mounting, do I have to find roof beams and screw into them, or I can just put screws into roof plywood, and add vhb tape for silicone, and perhaps glue for silicone, and some sealant?
Did I miss anything regarding installation on flat roof?
If anyone has related experience, I would appreciate your thoughts/ideas.
Thank you.
Thank you.
