Rich585
A couple of months ago I posted an idea of a small system to keep my lawn tractor charged. The goal was to re-use / re purpose what I had and just buy minimum. This is my first step into solar world.
I installed a couple of 12V RV lights and a small 200 W inverter.
I may not have kept that rule about keeping price to min (got to have a little fun) but here is what I have built so far. The system so far is doing what I need it to do.
The intent was to learn basics, and if I make any mistakes learning, it is not on a big system.
The lawn tractor connects to the load output of the SCC.
I have automotive blade fuses on the power to the lights, inverter (direct to battery 15A), Batt+ to SOC (15A), Load to Lights (3A) and to Lawn tractor (15A).
In the breaker box I do have a 10A fuse from the solar panel. (12 AWG solar cable wire).
The battery is a 65A AGM marine that is 8 years old (took out of my boat). The battery is worn. Even having the 2 lights on (12 W) pulls the battery voltage down to 12.4 V after 5 minutes, but it is a storage shed, not a work shop so I will see how long it lasts.
I am going to install a ground from the solar panel and the lightning protection things in the panel. I need to order some grounding wire (green) and a grounding rod to stick in ground behind the shed.
Let me know what you think and any advice is appreciated!
Solar Panel - Started with a 50W
Fuse / breaker panel
Light in Shed
Light in Shed
