okaygolombruler
Hello, newbie here with what is starting to look like a 'stump the chumps' question. :/
Demand/Usage: projected 27MWH/year, rising to 35MWH/year as we finish electrification and move to EVs. Peak power (less EV chargers) ~15kw.
I'm looking to install my system in two phases.
Phase 1, this year: 30-35kw of panels + the remaining charge controllers, inverters, bus bars/panels, BoS, ... needed to sell back to the grid.
Phase 2: (future work) battery bank sized according to our evolving usage and self-sufficiency targets.
I understand that after Phase 1 we may not have adequate power to run loads during a power outage.
I don't want to spend a bunch of money on battery tech I don't want (LFP) up front when the tech I want (VRFB) is coming down the pike. (Worst case, I end up having to install LFP batts later.)
So far every vendor I've talked to has said "you can't run DC-coupled / string inverters without a battery", and I can't figure out why. (other than not wanting support calls / wanting to sell batteries...)
In AC-coupled, microinverters convert DC to AC and push it towards your mains without any kind of battery. No grid, no power, have a nice day.
In a batteryless DC-coupled system, MPPT/charge controllers convert DC to lower-voltage DC and feed it to inverters which convert DC to AC and push it towards the mains without any kind of battery. No grid, no power, have a nice day.
1) What am I missing here?
2) Is there a minimum amount of battery required for a DC-coupled system like this to work safely?
3) If there is a minimum, how is it calculated? (max inverter draw? max charge controller output? max power slew rate on the DC bus? max AC load?)
I could understand wanting to 'smooth out' the power available to the inverters (say from a passing cloud bank) but I feel like I'm missing a core concept here. Any ideas?
