Jim Burrow
- Jun 27, 2020
- 516
Found out something about a little solar system. I have the MTTP 2424LV-msd (all-in-one) controller/inverter. Up until this time I have been using a 140-watt fan or 100-watt heat lamp as my load from my 2424lv. For several months the 2424lv has been sitting on my workbench in my hanger and working flawlessly. But yesterday I brought the system home so I could connect solar panels to the system as I don't have access to the direct sun at my hanger.
With respect to my house, all lights are LED so while checking my system before connecting the array panel. (System not connected to the house yet) I used one 20-watt led bulb and on battery power, but all the bulb would do is flicker on and off. I added 3 more 9-watt led bulbs and all the light would still do is flicker and not come on. So I figured the controller isn't putting out a high enough initial voltage to trigger the LED bulbs. So I removed the LED bulbs and connected a 40-watt incandescent bulb and got the same results.
It wasn't until I increased to Load with a 100-watt incandescent light bulb that the light would come on without any flickering. I then tried a 60-watt bulb with different size LED bulbs. Every time the lights would flicker and not come on until I reached 80 watts.
I'm now using a 60-watt bulb with a 20-watt LED bulb and the lights don't flicker and they come on instantly.
So it looks like my 2424lv needs an ac load of a minimum of 80-watts. So when I get around to finally connecting my system to the house, I will have to make sure I always have at least 80-watts of power on in the house or my controller could cause hell with the TV's and my computer and other electronics.
However, this shouldn't be a problem as the lowest power drawn in my house is 154-watts of electronics and refrigerator after I and the wife go to bed.
