SolarAntics
Hi,
In a best effort to not kill myself doing what I love doing; I would greatly appreciate y'all's thoughts and advice on my plans to build my first solar power system; starting here with the battery bank. I have 3 different brands of lifepo4 batteries, with different capacities, that I want to combine to make a 24v bank.
(I have decided to keep my developmental progress recorded here on this first post for context and quick reference. The most current plan and system information is at the bottom - also here is a link to my full build - it's a work in progress - https://diysolarforum.com/threads/m...kw-lifepo4-2500w-inverter.95256/#post-1283778)
The idea is to connect two Brand A 100ah batteries in parallel to a first set of bus bars, and a Brand B 180ah battery to those bars - but in series connectivity to the bars to make 24v from them to the main bars.
Then, connect those bus bars to two main bus bars; which are connected to two Brand C 180ah batteries connected in series.
So this should look like a 24v 740ah battery to the MPPT charger.
(MEGA MISTAKES - please disregard this diagram)
REWORKED DUE TO MEGA MISTAKES ABOVE
I haven't boughten the yellow brand b battery yet, so it sounds like I will need to buy two 100ah to make another 24v pair to make two relatively close capacity groups.
EDIT 3
Thinking wiring bus bars to MPPT staggered like so - Is it better to wire the pos closer to one group versus the other due to group capacity variations (200ah vs 180ah)?
(Above has stupid wiring creating shorts)
EDIT 4 (based on recommendation of using a balancer)
EDIT 5 (fixed balancer mistake and created closer capacity groupings for parallel connection between 180ah group and the 200ah group)
EDIT 6 (Need to balance each series independently)
EDIT 7 - (I am stuck with Brands B and C 12v batteries, and find that purchasing a 24v battery is nearly the same as the cost of two 12v, a balancer, and the extra cabling. Save some space as well)
Context on full system build plan:
Questions:
Will this work, and does anyone have any advice?
When making parallel connections, those cables need to be of equal length?
Thanks for your help!
EDIT 3
- For my RV
- A 24v 2500w pure sine wave inverter by VEVOR
- Most draw at one time would be the microwave/air fryer that pulls 1700w plus the RV lighting, water pump, some draw for the water heater startup, and a 45amp 120vac rv converter to charge and maintain an independent 100ah lifepo4. I will likely be adding a 12v fridge that would pull 60w (will plug into 120vac).
- MPPT 24v charger is from LiTime rated at 30a output and 100v max input >> Connected to 800w total of solar (two 400w arrays in parallel (each - OCV=47.2v SCC=11a))
- The 120vac charger (LiTime 29.2v 40a) is isolated for charging by means of a generator for emergencies only.
- I will cut the solar charger off to batteries using a switch when not connecting solar panels and/or using the generator (panels will be disconnected anyways). The 120vac charger goes to an outlet facing outside my rv (again to reiterate, this is completely isolated from any other system) to connect my generator to.
Questions:
