wpns
Solar Joules are catch and release
I honestly can’t parse your drawings. You’ve got missing wires, you’ve got added wires, you’ve got wires shorting out battery terminals. If you don’t understand what you’re doing and you start building this you are going to have at the very least excessive currents as you assemble it, and worst case, overheating, venting, and explosions. Please do not do this without a thorough understanding of batteries and electricity.
Series connections of batteries should all be the same battery type , manufacturer, model, and capacity.
Each set of series batteries should have an interbattery balancer/equalizer.
Putting different capacity batteries (or strings of batteries) in parallel works just fine if your wiring is done properly and you have the appropriate over current protection devices.
Honestly, you are adding complexity and confusion, you should really be using batteries that are at the intrinsic voltage of your inverter, or you going to be back here in six months or a year asking us what went wrong.
