vivekgangwar02
Hi, I'm from India using Flooded lead acid batteries, I have the battery so called a solar c10 150AH battery, where they claims 60months warranty and 96Months of lifetime.
I recently moved to a 24 volts system, due to budget issues I mixed the 4 years used lead acid with a new one of the exact same make.
I was pretty sure on this because on a 100amp load tester I tested the condition(the load bearing capacity) of the old FLA, it showed in excellent condition.
But i'm sure the old FLA has increased internal resistance comapared to the new one. I am concerned because when I'm charging my batteries on MPPT, I see a big voltage difference in both individually. That difference is around 0.8 volts. I dont see this big difference during discharging.
My question is, is there any metric to decide based on the voltage difference between them to know if I really need to replace the old battery from the system.
I'm currently have 550watt of panels and Im planning to move to 1100watts, which will output 40amps for each battery at 24volts.
Thank You
Thank You
