bsr
Hello
We setup our system to power a farm market & small kitchen. Started off with 2 xw pro, but got 4 more to have 3 phase stacked configuration.
I currently have 2 EG4 PowerPro WallMount batteries ( each 280Ah | 14.3kWh)
To increase the storage, ordered EG4 LL-S Lithium Batteries Kit | 30.72kWh | 6 Server Rack Batteries
1. What is the best way to physically connect them.
Researching on this, using a common DC bus is the most common option. Victron Energy Lynx Power In is a good option, but max out atr 1000A. Is a custom bus bar the best option? can you please give a good resource or recommendation for building one, which is future proof. Say, if we add one more set of 6 Server Rack Batteries.
2. I read somewhere EG4 PowerPro uses the same BMS as EG4 LL-S. Can I connect them together though battery COM port? Will they work as single unit, and distribute the load.
Thanks
bsr
Thanks
bsr
