sailingharry
I am about to pull the trigger on EVE cells, about 300Ah each (not sure if 280 or 314 or something in between) for my sailboat. My current battery is 740Ah of AGM, and works wonderfully -- this would indicate that I should go with 8 cells (2P4S) for a significant step up in available power, especially if I spring for 314Ah cells (a 628 Ah bank with easily 500Ah available, compared to my existing bank with less than 400Ah available and challenges charging above 90%). BUT, I have this nagging thought that someday, I'd love to install AirCon (doesn't exist at present) and I could have a useful amount of run time if I hit evening at 80% SOC and am willing to run down to 15% SOC overnight. Yeah, that would be a brutal recharge the next day -- but it would be nice to have that option. To make that viable, I would really like a ~1000Ah bank (3P4S). But this is in the future. I have no need for it now, and LFP is going noplace but down.
Here's my thought. Buying 3P4S is an extra $400, and adds ZERO value at present. What if I buy 2P4S, and build my entire structure (box, bus bars, etc) for 3P4S and install 4 blocks of wood as the extra 4 cells. At some point, after I've installed AirCon and sussed out the viabilty of actually running on battery, I buy 4 new cells and they are a very simple drop-in to the existing bank (yea, balancing and all that -- nothing is "simple"). And, yes, in 4 years, there is a good chance that the new cells will be the same size (Eve likes this form factor) but they are likely to be larger (say, 350Ah).
Long held conventinial wisdom, dating back to flooded batteries, is that you can only parallel batteries of similar age, size, and capacity. I suppose that wisdom carries over to LFP. I've never bought that idea (but I've never actually mixed batteries either, so I don't have any experience). If the top and bottom of the charge curve (the knees) are the same, they should top balance out and hit 0 SOC together. Any cell that somehow gets there first will simply stop contributing -- it won't continue to go further (its not the same as in un-monitored series cells -- old NiMH for instnace -- where a cell can hit zero and be reverse charged and ruined. In my view, adding a third cell set to an existing 2 cell battery at some point in the future is certainly worse than tossing the old stuff and buying all new, but no worse and probably better than buying the full scale today and letting it age.
Has anyone added new cells to an old bank, and experienced negative outcome that you can share?
