chilly2
Amateur fry cook
- Sep 14, 2021
- 221
The breaker panel in my house is a lug load center, with no main breaker of it's own, so to de-energize it I have to go outside and flip a 100A breaker by the meter.
When the grid was down, I *had* a WZRELB split phase inverter ready to run the house, just a breaker flip away. There was a big notice on the procedure. Grid down - Go outside, turn off the 100A. Come back, turn on the breaker to the inverter. Grid up - turn off the inverter breaker, turn on the 100A outside.
You can see the obvious risk of human error, and despite years of diligently following the routine, this weekend I hadn't had my coffee (as the power was out) and forgot to turn off the inverter's breaker before restoring the grid power.
It was rather underwhelming actually. As I flipped the outdoor breaker I was like 'oh.... crap'. Walked inside, and there it was, just off, with a fried electronics smell.
A postmortem revealed nothing obvious. It looked pristine in fact. Alas that was as far as it went as I didn't know what else to check, so the inverter is toast. I thought I trusted myself enough, but still made the mistake, so I'm going to pay an electrician to run the 100A into a manual transfer switch, and put the replacement inverter there.
Oh well. A lesson learned!
