hotsteppa
- Feb 1, 2022
- 4
Hey everyone meet the Hot Steppa. This is our new Mobile DJ Booth and Popup shop. It is in the process of getting cleaned up and ready for the road now.
I would love to get some guidance on your all suggested solution for powering our mobile sound system (this will be outside of the van, and we will be DJing inside).
My initial idea was to put a roof rack on top (roughly 6 x 11') and throw some of the Santan Solar panels on top, and run them into a Bluetti AC200P. This way we could top off at home before we left, and top off from the 12V (or install an inverter on the van battery system), as well as the solar panels.
I have done rough math based on the draw of our sound system (2 18" subs, 2 12" tops, 2 8" tops, some other monitors and DJ Gear) and am hoping that I can get 3-4 hrs. I can't tell for sure until I get it and do a real world test but rough math figures around that. If needed I could add additional B300 batteries.
After some thought, we are concerned the roof might need additional reinforcement if we did that, so was considering going for the package with the 3 PV200 panels. While they are pricy, the upside would be no roof rack needed which saves a bunch, and we could position and angle them on the roof to get maximum output. It also solves issues with security concerns about panels and having to cut a hole in the roof.
With that in mind, I was drawn to these mobile solar generators bc we can easily remove it from the van for security purposes, and for some events we may be outside of the van and want to move the power and use the van for vending.
First question is, are these systems going to hold up if they are used hard on a regular basis (a few days a week @ 6 hrs), or are they more designed for occasional backup use?
Second question, is there something else out there better/more economical that will cover all the above concerns?
I have seen some of the newer MPP systems that Will has posted recently but they seem like they are more designed for permanent installation.
Thank you in advance for your help.
