WoodsieLord
Hello everyone,
After almost a year working with my electrical installation, UPS, battery bank, and DIY battery monitor and such, I'm close to the last phase of the project: Putting the panels in place.
I have a few constraints that I want to state before going into further detail:
- The roof is flat, with membrane. It's actually the 10th story of a building.
- There are no fall protections. Borders are 20~25cm (8~10 inches) tall just to guide rainwater to drains. I climb there pretty often and I'm used to the lack of walls: I play safe, I stay far from the dangerous edges.
- I don't want to bolt structures to the roof. I'm planning to use dead weight to help against winds.
- I'm willing to add one or two "guy wires" (funniest name. ever.) that I could bolt up to two walls, whose edges are safe to approach.
Well, that being said, the vanilla constraints are as follows:
- 4 Panels, 2m x 1m (~40 by 80 inches) each.
- I want to be able to tilt them up to ~50 degrees.
My current "most appealing idea" is making a cubic (parallelepiped? I think) iron frame that would sit on the roof surface stuffed with water filled soda bottles as dead weight. On top of the structure, I would fix a flat frame that would hold tight a single panel while pivoting (using hinges) in a single axis to achieve the desired angle (upt to 54º would be ideal).
+Benefits: Such structures would be fairly easy to transport/move to another location. I don't need to build them on the roof itself! I could work in a safer environment then move them to their position, and finally add the dead weight.
-Downsides: I need to build four of them for my current test setup. I would need to build two more (when AND if I get to buy two additional pylons--Sorry!, panels). Fixing many structures in place with "guy wires" is way harder than fixing only one.
What do you think? Do you have a better idea to improvise panel mounts without bolting or damaging the flat surface?
Thanks a lot for reading! I know I have a tendency to write a lot and my english is not pretty.
PD: I posted int his subforum, because I think my project is absolutely unconventional, fairly unsafe, has a "long term test" nature that does not comply with common standards. Sorry if this is not uncommon or vanilla...!
