Monitoring data from my MPP LV2424 with Python, MQTT, and InfluxDB
SajgZi
Hey all, I hacked together some scripts I saw on here and elsewhere to get data flowing from my MPP LV2424 hybrid inverter to a Grafana dashboard. There are a few steps involved:
  1. Wire up the inverter to a computer running linux with a USB to serial adapter (the built-in one is funky)
  2. Poll the inverter with the mpp-solar pip package and put the data into MQTT (message queue)
  3. Have another script monitoring MQTT for new data and sending updates to InfluxDB
  4. Use Grafana to graph it all
This is what my dashboard looks like. I have 2x310W solar panels (that put out around 450W on a good day), a LV2424, and 8x 260Ah LiFePO4 battery cells for a 24V nominal configuration. I also have a JBD 8S BMS but don't have a write up for that portion complete yet.
I did a full write up of everything here - https://austinsnerdythings.com/2021...verter-data-to-mqtt-and-influxdb-with-python/. There is a decent amount of code:
command to poll the inverter and put data in MQTT (this runs every minute via cron):
Code:
/usr/local/bin/mpp-solar -p /dev/ttyUSB0 -P PI18 --getstatus -o mqtt -q mqtt
python script to listen to the MQTT inverter topics and insert to InfluxDB:
Code:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
# originally found at/modified from https://github.com/KHoos/mqtt-to-influxdb-forwarder
# forwarder.py - forwards IoT sensor data from MQTT to InfluxDB
# Copyright (C) 2016 Michael Haas <haas@computerlinguist.org>
# This program is free software; you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation; either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY; without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
# GNU General Public License for more details.
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software Foundation,
# Inc., 51 Franklin Street, Fifth Floor, Boston, MA 02110-1301  USA
import argparse
import paho.mqtt.client as mqtt
from influxdb import InfluxDBClient
import json
import re
import logging
import sys
import requests.exceptions
class MessageStore(object):
        def store_msg(self, node_name, measurement_name, value):
                raise NotImplementedError()
class InfluxStore(MessageStore):
        logger = logging.getLogger("forwarder.InfluxStore")
        def __init__(self, host, port, username, password_file, database):
                password = open(password_file).read().strip()
                self.influx_client = InfluxDBClient(
                        host=host, port=port, username=username, password=password, database=database)
        def store_msg(self, database, sensor, value):
                influx_msg = {
                        'measurement': database,
                        'tags': {'sensor': sensor},
                        'fields': {'value' : value}
                self.logger.debug("Writing InfluxDB point: %s", influx_msg)
                try:
                        self.influx_client.write_points([influx_msg])
                except requests.exceptions.ConnectionError as e:
                        self.logger.exception(e)
class MessageSource(object):
        def register_store(self, store):
                if not hasattr(self, '_stores'):
                        self._stores = []
                self._stores.append(store)
        @property
        def stores(self):
                # return copy
                return list(self._stores)
def isFloat(str_val):
  try:
    float(str_val)
    return True
  except ValueError:
    return False
def convertToFloat(str_val):
    if isFloat(str_val):
        fl_result = float(str_val)
        return fl_result
    else:
        return str_val
class MQTTSource(MessageSource):
        logger = logging.getLogger("forwarder.MQTTSource")
        def __init__(self, host, port, node_names, stringify_values_for_measurements):
                self.host = host
                self.port = port
                self.node_names = node_names
                self.stringify = stringify_values_for_measurements
                self._setup_handlers()
        def _setup_handlers(self):
                self.client = mqtt.Client()
                def on_connect(client, userdata, flags, rc):
                        self.logger.info("Connected with result code  %s", rc)
                        # subscribe to /node_name/wildcard
                        #for node_name in self.node_names:
                        # topic = "{node_name}/#".format(node_name=node_name)
                        topic = "get_status/status/#"
                        self.logger.info("Subscribing to topic %s", topic)
                        client.subscribe(topic)
                def on_message(client, userdata, msg):
                        self.logger.debug("Received MQTT message for topic %s with payload %s", msg.topic, msg.payload)
                        list_of_topics = msg.topic.split('/')
                        measurement = list_of_topics[2]
                        if list_of_topics[len(list_of_topics)-1] == 'unit':
                                value = None
                        else:
                                value = msg.payload
                                decoded_value = value.decode('UTF-8')
                                if isFloat(decoded_value):
                                        str_value = convertToFloat(decoded_value)
                                        for store in self.stores:
                                                store.store_msg("power_measurement",measurement,str_value)
                                else:
                                                store.store_msg("power_measurement_strings",measurement,decoded_value)
                self.client.on_connect = on_connect
                self.client.on_message = on_message
        def start(self):
                print(f"starting mqtt on host: {self.host} and port: {self.port}")
                self.client.connect(self.host, self.port)
                # Blocking call that processes network traffic, dispatches callbacks and
                # handles reconnecting.
                # Other loop*() functions are available that give a threaded interface and a
                # manual interface.
                self.client.loop_forever()
def main():
        parser = argparse.ArgumentParser(
                description='MQTT to InfluxDB bridge for IOT data.')
        parser.add_argument('--mqtt-host', default="mqtt", help='MQTT host')
        parser.add_argument('--mqtt-port', default=1883, help='MQTT port')
        parser.add_argument('--influx-host', default="dashboard", help='InfluxDB host')
        parser.add_argument('--influx-port', default=8086, help='InfluxDB port')
        parser.add_argument('--influx-user', default="power", help='InfluxDB username')
        parser.add_argument('--influx-pass', default="<I have a password here, unclear if the pass-file takes precedence>", help='InfluxDB password')
        parser.add_argument('--influx-pass-file', default="/home/austin/mpp-solar-python/pass.file", help='InfluxDB password file')
        parser.add_argument('--influx-db', default="power", help='InfluxDB database')
        parser.add_argument('--node-name', default='get_status', help='Sensor node name', action="append")
        parser.add_argument('--stringify-values-for-measurements', required=False,      help='Force str() on measurements of the given name', action="append")
        parser.add_argument('--verbose', help='Enable verbose output to stdout', default=False, action='store_true')
        args = parser.parse_args()
        if args.verbose:
                logging.basicConfig(stream=sys.stdout, level=logging.DEBUG)
        else:
                logging.basicConfig(stream=sys.stdout, level=logging.WARNING)
        print("creating influxstore")
        store = InfluxStore(host=args.influx_host, port=args.influx_port, username=args.influx_user, password_file=args.influx_pass_file, database=args.influx_db)
        print("creating mqttsource")
        source = MQTTSource(host=args.mqtt_host,
                                                port=args.mqtt_port, node_names=args.node_name,
                                                stringify_values_for_measurements=args.stringify_values_for_measurements)
        print("registering store")
        source.register_store(store)
        print("start")
        source.start()
if __name__ == '__main__':
        main()
And then a systemd daemon to keep it all running.
The individual scripts I used were https://github.com/jblance/mpp-solar and https://github.com/KHoos/mqtt-to-influxdb-forwarder.
Once I'm done with the BMS write up I'll post that too.
SajgZi
This is pretty awesome. I have been using solar assistant but I may give this a shot
There is a 99.9% chance they're using the same polling method as the mpp-solar package I posted. I wasn't aware people were charging for this! Their system does look pretty though. Ask my wife - she'll confirm I prefer function over form haha
coil1002
Solar Wizard
Wa State
Well I would like something I can edit. I think they really missed the mark by not opening this up for the ability to customize the dash boards. And I cant gain root to get in ssh wise and edit the scripts
SajgZi
@curiouscarbon MQTT is perfect for most monitoring around the house! I can't tell you how many active topics I have. Multiple temperature sensors, humidity, weather station, RTLAMR (reading my gas and electric meter signals out of air), and more. Check out my linked blog for some details
coil1002
Solar Wizard
Wa State
If you already run solar assistant then getting your data into home assistant is easy:
WHY? WHY did you have to send me down this road of Home Assistant? Its like an addiction, or a bad relationship where its not great but she does a lot of what you want even though she is unstable. All kidding a side Home assistant is pretty awesome if you want to put in the time. I just wish it was a tad more stable.
SajgZi
Also wish it was easier to edit the config files and to not need to restart the entire service when you change a single setting
