Hello Curiouscarbon,
Unique "handle"!
I'm in the beginning stages of installing a large system---40 panels---here in Fort Bragg, CA on California's north coast. Yesterday I had a phone conversation with a good friend---one of the smartest and most energetic people I have ever met, and I'm 81. He had installed a system that originally fed only one utility company meter. He was able to monitor his usage accurately with that setup---presumably online.
Then he---Brian, the other one---decided to aggregate with a second utility company meter on his property, and the usage monitoring system no longer worked. After many phone calls to PG&E---the utility company---the answer was that they had no plans for fixing the problem.
I'm in a similar situation in that we plan to aggregate two meters, one at the house and one at the shop---I make classical guitars. Part of what will make this system pay it's way is to use any excess energy that we produce for heating, thereby reducing our propane usage. We're out in the sticks and have to use propane at somewhat over $4.00 a gallon, delivered. I'm figuring that we need an accurate way to keep track of our total electrical usage---and excess energy available---to make this work. Connecting the house and shop into one system is an expensive, but possible, alternative.
I can get further details on his system from "the other Brian", if they would be helpful.
Cheers,
Brian
